Are the cameras on the arms interchangeable?
jftman
Western NY
I found the left front camera's photo electric plate cracked. The drone was plagued with V30 Vision sensor error persistently.
I had some parts and ended up using the camera and internal plate by installing the module onto the base and ribbon.
After assembly I compared the angles of both front cameras with a known good S2.
The mounts determine the angle not the top portion (module).
The part numbers of old and 'new' are different, if they are part numbers.... But Can anyone definitively strike using the modules from a location other than the one here, front left.
romanski
