Crowd Counting at Public Venues
V5-DVPLLC
Does anyone use their Skydio in conjunction with a city's public safety for crowd counting at venues such as 4th of July Parade, car shows, etc??
Greetings from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you!
In the USA, the FAA requires a waiver to fly over people or meet the following guidelines
FAA Part 107 - Operations Over People January 2022 USA​
This is only relevant for Part 107 Operations under the FAA in the United States of America!!
This is from April 2021 so the actual dates might have changed a few days here or there but they are very close. At this point it's irrelevant!!
Ops over People (OOP):
There are 4 categories of OOP.
Ops over People, Category 1:
The PIC must use an aircraft that:
•Weighs less than 250g (.55 lbs.), and
•Contains no “exposed rotating parts that would lacerate human skin upon impact with a human being”.
•There are no manufacturer requirements for Declaration of Compliance. It will be incumbent upon the PIC to make sure the UAS qualifies.
•No sustained flights over open air assemblies w/o RID (concerts, construction sites, etc.).
•Goes into effect on 4/21/21.
•No flights over open-air assemblies w/o RID.
Ops over People, Category 2:
•Possesses a Declaration of Compliance.
•Does not transfer more than 11 ft/lbs of KE.
•Has no rotating parts that lacerate skin.
•Does not contain any safety defects.
•Labeled as such.
•Maintained records & instructions.
•Implementation date is dependent on when manufacturers can get their Declaration of Compliance approved.
•They can start submitting them 9-12 months after 4/16/21.
Ops over People, Category 3:
•Does not transfer more than 25 ft/lbs of KE.
•Labeled as such.
•The PIC may not fly above open air assemblies.
•May only operate over people if:
•On a closed-site with notice given, or
•If person is directly part of the operation, or
•Under shelter or stationary vehicle.
•There is no RID requirement for this category.
Ops over People, Category 4:
•Possesses a Part 21 Airworthiness Certificate.
•Operated within the Flight Manual.
•Be RID compliant.
•Have very detailed records.
•Have all records accessible by the FAA and/or NTSB.
•Implementation date is dependent on when manufacturers can get their Airworthiness Certificate approved.
•They can start submitting them 6-12 months after 4/16/21.
Ops Over Moving Vehicles:
•Qualifies for OOP operations
•Categories 1-3 must:
•Remain in a closed-set with notification, or
•Not maintain sustained flights over vehicles (basically they must be transitory).
•Category 4 must be operated in accordance with their Flight Manual.
•All operations over moving vehicles are tied to the timeline of the category of OOP they fall under.
Thanks, I should have specified that the concept is to have a protected area to fly the drone (either cordoned off or maybe on the top of a building) so it would not be flying over people, but looking at the crowd from the side and taking video or pictures to get crowd size.
Reactions: GFields
That should work fine.
