Function: back to beacon
haveaniceday
Hello Together
When I ride my mountain bike, I only have direct access to the Beacon, which is placed on the handlebar.
Now it may be that the Sykdio2 is away from me when I stop. So that I can easily initiate the landing, it would be great if I can make the drone fly directly back to the Beacon with a button (without steering).
Is there a trick how I can do that?
BR
Markus
While in the track mode you can press the “-“ button which will bring it in pretty close to you.
I use this method all the time, after I reel it in I use the wand to position it where it's easy to walk up to. If you look at the very end of this video you can see it.
