Limited to 10 mph?
eakaplan
I’m a new skydio owner. I put on new props and flew manually using the controller. I wasn’t able to get it above 10mph. When I hit RTH, it flew backward. Any suggestions?
I'm sure you noticed the poor wireless range on the S2, it returns backwards to get the best signal since antenna is located in the rear of the drone. I don't think you can adjust the RTH speed, how ever you can use the boost button when you fly and also in setting there is speed adjustment from 10-100% if you don't like the boost button idea.
Page 6 / Flight sensitivity
Reactions: eakaplan
