SKYDIO 2+ Antennas mounted in Black Top Section assembly made harder
jftman
Western NY
A crash cracked the blue frame. I went after tearing it apart like a Champ. Except I now believe I should have pulled off the antenna connectors and NOT messed with the folding spring assembly.
Now getting around to putting it back together. It seems apparent that threading the antenna wires through the frame channels is the way to do this at the jump.
I am trying now to figure how the retractable, fold down units go back together. I took a Pic but so long ago. I my not find it!
Can someone post a Pic. Am I right that taking the body apart to change a motor on S2+ ONE Must leave the Antennas in place and snake the wires out??
After putting these in place I had to loosen both and adjust the insert and pivot so the parts laid flush, not stepped. Perfect Notch that has the floor smooth beneath the antenna's
