Skydio 2 Motor Shaft on Lathe
jftman
Western NY
Hello,
Has anyOne have the occasion to press out the shaft on our motors?
Mine is a good motor and only needs a proper shaft lathed to original specs.
AnyOne figure making a new shaft is doable on a hobby lathe and want to do it?
I do not know in which direction pushing out the broken one should go.
The top end is snapped off. A depth gauge would give the required portion.
Checking at both ends showed the flat disk larger in diameter than the through side. Cir Clip and good tolerance fit will do the trick.
