Skydio Controller battery charging
bikerdave
Has anyone ever noticed how long the battery takes to fully charge in the Controller? I charged it overnight, and it was good to go. Turned it on for about 5 minutes to set up a tablet adapter. Put it back on the charger for a "top-off". It's been on the charger for 4 hours now and hasn't gotten to a full charge, according to the indicator. It seems that it should be a LOT faster than that!
The best charger to get for charging multiple Skydio batteries.
LinkOn Ganius 166W (136W Certified) Wall Charger GaN Tech 100W USB-C PD3.0 PPS and 18W USB-A QC4.0+ for MacBook 2019 Dell HP Surface Lenovo Samsung S20 Ultra Note 10+ Portable Travel​
Here is why.
You will need the 2 battery adapter.
The adapter has 2 usb-c ports.
You can charge the 2 batteries PLUS an additional device ALL at the same time. very quickly.
Additionally the adapter with batteries is a high capacity power bank that allows you to use to charge any usb devices.
This charger has the capacity that allows each battery/device to charge optimally.
Hope this helps.
