Accessories for the Skydio2
Another good source for an S2 battery cover is available at Drone Valley.
Not sure it makes much/any difference but the Drone Valley Battery covers are advertised to made out of aluminum instead of rubber.
That's a solution waiting on a problem; a small square piece of black elec tape would be my solution.
Or make you own accessories if you have a 3D printer!
Reactions: Blueskybob
True but by using a 3D printer one has to choose the correct type of composite material... flexibility.... wear resistance... tolerances....etc., etc.
Ha, part of the fun, this is not rocket science but simple drone accessories that you can make yourself for pennies.
May be so but only time will tell what the best choice turns out to be.
Might even try several vendors and just chose the one I like best.
Well to start with I'm not selling anything!
If you have a 3D printer you can download my files for free to print as many as you want.
You can spend your money anyway you want no skin off my nose!
I wish I had a 3D printer but I wouldn't use it enough to justify buying one. I'd be printing out the tablet adapter.
Dibert
