Controller tips and tricks?
NEDroner
I've been using the sky controller more often lately for cinematic footage.
Despite all of the complaints I've read about range, I consistently get 1,200-1,500ft of range which is the limit of my VLOS (even w/strobes). I'm satisfied with that.
However, I find the controls "laggy" compared with other drones and controllers I've flown.
When I push the control sticks, the Skydio responds very slow initially and I'm encouraged to push them further which often results in "over-control" movements.
I've learned to push the sticks a bit, observe the initial/small response from the skydio, and maintain the stick position and wait. ...because after a second or two (or three?) the skydio will respond more strongly to the original position.
This makes it challenging to coordinate yaw, lateral, and front/back motions due to this lag.
Would like to hear tips and tricks for the controller settings you use or techniques for using the controller in general.
I believe there is a way to adjust the responsiveness within the app for the sticks, may be able to get the jerkiness smoothed out. Sorry I don’t remember which menu it is under.
Click the little gear wheel on the app, go to controller - flight sensitivity. There you can control roll, pitch, yaw and throttle.
My tip is "Don't forget about the zoom paddle." It makes a great two-control move with only one lever.
You can combine the zoom with other motions, like adding a little forward motion during the zoom to hide the fact that you didn't have your subject perfectly centered to start with.
Reactions: gsrider
