Flight time remaining on an SD Card
vanweric
I was trying to figure out how much recording space is left on my SD card, and couldn't find it through the Android App's interface. The menu that selects recording parameters (frame rate, resolution, etc) gives a number of minutes, but it doesn't appear to change as I change those options.
How can I see how long I can record with my current settings before my card fills up?
Thanks!
Not sure if this helps but I can 5~6 flights on a 128G filming 4K/60 HDR, I've never ran out of memory but 5~6 flights is the limit of what I attempt in a single outing. The Beacon will last 6 flights also.
I'll take a look at some SD2 files and see if I can come up with the memory (MB/GB) per min of flight.
Edit: just looked, @ 4K/60HDR it's pretty close to about .75GB per min of flight, I don't record any audio but I doubt that's much of a factor in the file size.
barneew
