Key Frame Question
Winchester
When Im using the Key Frame option....will pictures automatically be taken at the points I designate or is that done manually?
Good question I haven't yet used the Key Frame option but I would like to know the answer to this as well🤔
Keyframes is for video shooting. Fly the Skydio to a position in the sky, point the camera where you want it to look, then set a Keyframe. Proceed to the next spot, do the same. Repeat until the full route is set up. Once everything is ready then execute. It makes for some interesting flight with the potential for a lot of creativity. Cue the annoying music:
When flying a keyframe path, Skydio will be making a video, from which you can grab snapshots if you choose.
sambass
