Thank you Dustin!
I can't get more then 1500ft before the video is choppy (No WiFi around)This guy always does consistent and reliable range tests. I was surprised when he said he was impressed with a mile under perfect conditions, especially when he got almost 3 1/2 miles out of the Mavic Mini. However, the footage was beautiful, the drone did a good job of returning home and I'm glad they fixed the battery management problem I had with the drone.
Also funny how the telemetry shows -5FT (about 7min in to the video)
Over a mile out in controlled flight before pixelation begins ... more than enough for a guy that flies only a little BVLOS. <GRIN>Thank you Dustin!
Except Dustin achieved miracle result compare to anything else I seen.Over a mile out in controlled flight before pixelation begins ... more than enough for a guy that flies only a little BVLOS. <GRIN>
Wonder how sketchy flying gets if he turned on the way out and the on-board antennas came in and out of ideal orientation???
His test (other than being done in and out of fog layers) was done in ideal conditions with the S2's antennas in the ideal position for the entire flight.Except Dustin achieved miracle result compare to anything else I seen.
Don't make me post my results stand-in on top of hill over water, not a soul around ?His test (other than being done in and out of fog layers) was done in ideal conditions with the S2's antennas in the ideal position for the entire flight.
If he had turned the S2 chances are good that the results would not be any where near that miraculous.
Not trying to make you do anything... you do understand what I said about antenna orientation right?Don't make me post my results stand-in on top of hill over water, not a soul around ?
Once again, distance no big deal but I want strong video feed back.
Naturally, been around the block few timesNot trying to make you do anything... you do understand what I said about antenna orientation right?
Sense a lot of pent up frustration...take some deep breaths and maybe things will get better.Naturally, been around the block few times
If we point them out I hope so ?Sense a lot of pent up frustration...take some deep breaths and maybe things will get better.
For your sake I hope so also...If we point them out I hope so ?
Somebody is setting him self for eye opening experience when the time comes ?For your sake I hope so also...
Must be difficult to have expected perfection and not have gotten it...Somebody is setting him self for eye opening experience when the time comes ?
