Skydio Camera Crash Guard
IronSKy1
Approved Vendor
I have been very impressed with the Skydio drone's AI controlled Obstacle Avoidance .
My one concern as I am buzzing through trees and hugging the ground is:
What happens to the camera in a bad crash?
I designed these as a safeguard.
Does not work on Skydio 2+ yet because of 5g antenae
Weight:
One set left/right 32g
If your interested they are on ebay
those will likely adversely affect the oa and maybe the flight characteristics and will definitely void skydio care if found to be installed during a crash. even if you don't have skydio care, it would be risky to block those sensors in an effort to protect a fragile camera that is likely to be damaged in a crash anyway.
bad idea; sorry. i would never install these on my drone, regardless.
They are very low profile to top surface plus .1 and tapered away from sensors. Been flying fine for the past couple days. Anything attached to Skydio would most likely void warrenty .
Thanks for input. I will post if I have problems
