- Joined
- Aug 30, 2020
- Messages
- 14
- Reaction score
- 8
Hello all.. I'm looking for some input and perspective.
I went to land my Skydio 2 after a flight and while it saw its case during landing (indicated by the yellow ring around the case) it skewed to one side of the case while it landed, causing it to fall off the case as it was powering down and flip over. One of the props popped off the rotor as a result.. other than the drone getting some exterior dirt on it and surface dampness it seemed fine - the grass where I landed was still a bit wet from rains the night before. After cleaning it up it seemed to work fine again. I was able to put it up in the air and fly it again..
When I went to fly it again and land.. just to see if the landing system was working OK I tried it again.. and.. you guessed it.. fell off the case.
No strong winds.. I was surrounded by trees.. not even a gentle breeze when this happened.
She's back home and cleaned up and everything seems fine.. I flew it again just a few minutes ago and while she didn't - at first - want to land squarely on it's case I cancelled landing.. nudged it into position and completed handing and it otherwise seemed to work fine.. The only other issue was that I got a message when the Skydio was initializing that said "Fault: V30 Sensor Error".
So.. my question is - what did I do wrong? I'm not one to fault the drone.. this could easily be pilot error and I'm still learning Skydio's systems. I'm just glad it was only the height of the case off the ground when this happened.. could have been worse...
