Skydio X10D - Live stream using RTSP
BminhTFX
Hello Skydio Community,
I would like to ask if someone has tried the rtsp live stream feature in the Remote Controller of skydio x10d using ethernet cable ? I managed to get the live stream video through VLC on a windows laptop by connecting the remove controller and the laptop to the same wifi network, but the quality is not satisfied. Therefore I would like to use the ethernet cable (RJ45) with a usb-c adapter to connect the controller and my laptop. However I cannot get the stream using this approach.
Looking on the internet, I found this page: https://support.skydio.com/hc/en-us/articles/25838361582363-How-to-use-ATAK-on-Skydio-X10D and it seems that they do support the wired connection.
Could anyone tell me if you have managed to do it or if you have some information related to this problem ?
Thank you very much and I hope you have a good day!
And besides, do I need to install the driver for CDC EDM on windows ?
Is your intent to be able to have someone who's nearby you view the livestream without looking over your shoulder at the controller?
Hello, I just want to process the live stream from the drone on another machine at the same time
I’ve used the rtsp on the local server before and found the quality great through VLC link on a local computer but for ease of setup and use I’m stuck on the hdmi out into VLC or a recorder etc if the cable tying you is an issue there’s Bluetooth connects as well. Is there a need for the connection to be rj45?
sambass
