Any "Single" Skydio 2 battery charger out there yet?
skydioconvert
I always prefer buying extra batteries and just charging them slowly rather than possibly stressing the batteries by putting them through repeated quick high charge cycles.
I know its early but has anyone run across any 3rd party chargers designed to just charge a single S2 battery at a time?
Nope, nothing yet.
A battery charger for a single S2 battery is high on my to buy list.
Might even get two if the price is right <GRIN>
Couldn’t you just use the dual charger with a single battery? And maybe a lower wattage charge power source if you want to charge slow (maybe the Apple 18 watt)?
I maybe over cautious but buying 2 single chargers gives me insurance if for some reason the dual charger goes bad.
Whats not to say a fault in one part of the dual charger wouldn't shut down both charging receptacles?
Reactions: sshogg
Sure, absolutely, could be, though I don’t think they have a problematic shortage of dual chargers and remember you can charge one battery on the drone too if need be. :)
Just the price Skydio is asking for the dual charger is enough of a turn off for me to give it any serious consideration.
Additionally the need to include the S2 as part of a single battery charging procedure makes no sense whatsoever...ties up the drone from flying while also involving the drone in a process that could have problems.
Reactions: loyukfai and parkgt
I found some inexpensive 90w plug in the wall charges that are PD compliant. One has a built-in heavy duth Type C cable (6')
Here are the Amazon links. I'll have it tomorrow, Sunday)
90 W USB Wall Charger 1
Charger 2
the 2nd one I just ordered, so I'll have 2, just in case.
The Skydio charger is 65 Watts, these are 90 Watts and PD compliant, so it will safely charge the Skydio 2 faster.
I also ordered the Drone Valley usb plugs for the Skydio 2
Charger 2
Thanks Skyking... I'll take a look at these and add them to my buy list.
Charger 2
I have the second one you listed, it charges both batteries pretty fast, about 75min for 2 batteries that were down to a single bar.
dee cee
