SD2 app set up-- Help!
ngengs
Hi all,
Just got my SD2, and I need help with the app set up. I am charging the drone now as I downloaded the app and it says "Disconnected", so I press the "Connect" button. It then asks to "add the WIFI information for Skydio 2", with 2 boxes prompting for the WIFI and Password. Here's my newbie question... do I create my own WIFI name and password? Thanks!
It's best to download and read the manual, there's also a couple of tutorial videos on this matter.
Your Wi-Fi name and password are under the battery on the body of the Skydio 2.
@ngengs
Depending on what accessories (beacon, controller, etc.) you may have also bought, be sure to also also check out the separate accessory manuals that you can download from the Skydio website.
To see a lot of the important points,
is a really well put together series of videos to help you get started.
