Unable to charge skydio2 beacon
rajubhojwani
After plugging in skydio2 beacon charger the display screen displays flashing
Logo and even after some time it does not charge.wud appreciate if someone
Help me with the problem
Did you ever figure out a fix. I can tell you how to fix the problem. I had the same issue.
You have to pry the case of the beacon apart very carefully. The top and bottom are mostly stuck together with some type of soft sealing glue. Not really that hard to pry apart. Careful not to pry to deep and poke the battery or cut the wires. There is a black and a white set of wires attached to connectors at the bottom just above where the battery wires connect from the other side. Move those connection back and forth to make sure they have good contact. That all I did with 2 different beacons with the same problem. Have a picture of the inside that I will post when I make it small enough to post. Should be able to snap the halves back together and it should now show it charging or already fully charged. Good luck.
Clockburner
