3D Scan Max outdoor coverage?
LyleCDG
We have a job opportunity where I've suggested flying our 2+ with 3D scan to capture things our laser scanner won't be able to.
This is an industrial complex. The area of concern is a 1st story roof about 40 ft wide that is covering an alleyway between 3 & 4 story buildings over a distance of about 200 ft.
What can I expect time-wise for this flight to capture the roof top and the facades of the surrounding buildings?
Also, are there settings in 3D scan to not get so close to the structures? We don't need lots of detail, so if I stay 10-15 feet away from the walls and roof as opposed to the default 3 ft, I imagine I'll save a lot of time and have fewer unregistered cameras when processing later.
Any thoughts?
Thanks.
I've had to experiment with the setting. The controller will tell you how many images it will take begin the scan begins. I think it depends on how your going to process it into a 3D image, what file format. I still don't have that phase down yet. I've tried a few programs and haven't found what I wanted.. Good luck. please share what you learned
Time really depends on operator ability.
Facades - I do these manually and requires a little bit of skill to accomplish in a decent amount of time. I haven't been satisfied/figured out how to automate facades with 3D scan. So I just fly the drone and take the facade shots manually.
It gets pretty quick once you get the hang of it. This way you can control the drone staying away from the buildings too!
Doing easy buildings in the middle of no-where with little risk (trees and stuff) helped me get better and faster at doing facades.
Reactions: AERIALOPPS
