Setting Home Point
csperry
Sorry for the nube question. I'm using the controller. From what I have read once you launch the Skydio you can then set the home point. You do that by pressing the map icon on the phone (lower right) and picking a spot on the map. I have not had any luck doing it this way. Any help will be appreciated.
BTW the way Skidio why not set the homepoint at takeoff? Just saying.
Thanks
Craig
I hope you will not consider thread hijacking :)
Is there way to set home point to the controller? Same as on cheap drones like the Zino 2.
This is super handy for moving objects.
Thanks
