if they engineered  a tiny usb-c LTE dongle the port on top is in a good spot.  signal range and orientation would not be a limiting factor.
			Give it up, it will not happen, they will just release new version all together.if they engineered a tiny usb-c LTE dongle the port on top is in a good spot. signal range and orientation would not be a limiting factor.
My gut leans towards no drone manufacturer building extra stuff into the batteries for no reason.
Has anyone ever done a teardown of this thing?
 skydiopilots.com
					skydiopilots.com
				 alienth.cn
					alienth.cn
				 alienth.cn
					alienth.cn
				 alienth.cn
					alienth.cn
				 alienth.cn
					alienth.cn
				 alienth.cn
					alienth.cn
				FYI go see Mike's video at Accelerated heights. he tested this and says the Alientech mini antennas suck. they have better ones....the REAL RANGE issue with the Skydio 2 is the antenna design in the Drone itself. Poor sensitivity. Hence, POOR RANGE, which is also why the Drone flies backwards when it loses signal. if it immediately turned around when it lost signal it would take MUCH LONGER to regain signal/video/control. if adding $500 to my drone would give it FACTORY stated Range, i would be ALL IN. Love to see how you fare.....Good Luck !I haven't flown my SkyDeuce...Yet.
I did research this Anafi [our TX 's] upgrade.
Sophia from Alienth.cn confirmed my
Suspicion's...YES The DUO II Will Work
On the Skydio2 Anafi Controller...
$469.00
Plus--This Will Work On A Huge Variety of DJI Drones And others...
ALIENTECH DUO II 2.4G/5.8G Dual-band Signal Booster Antenna Range Extender With Accessories for DJI Drones
Best Amplifier Antenna Amazing 3-5 Times Extended Distance for DJI Drone's Accessories; INCL Mavic 2 Pro, Zoom/Mini/2/Air2/2S/3 RC-N1/RC PRO Classic/DJI RC, Platinum/Enterprise,Phantom 3/4 A/Advanced/Pro/V2.0/RTK,Inspire 1/2 Pro, Matrice 100/300/200/210/600 Pro/RTK,Smart controller,Cendence...alienth.cn
Don't Forget The::
..Adapter Kit to fit Your Anafi Controller
$39.90
The bracket with cables for remote control (RC) of Skydio 2 / Parrot ANAFI by ALIENTECH design
The product is 3D printed. It can be used in Skydio 2 / ANIFI remote control. After installation, it can be installed with ALIENTECH antenna and booster.alienth.cn
..Dual Suction Cup Mount
$15.00
Extension coaxial cables / bracket with two suction cups which can be Fixed on the car roof for ALIENTECH antenna signal booster
Each cable assembly is 100% Tested for continuity & a dielectric withstanding voltage of 1500 Vrms 50 Ω impedance, rated for 4.0 GHz Max. / 500 V Max. / -40°C (-40°F) to 85°C (185°F)Cable Type: RG-223/U coaxial with black, non-contaminating, Type IIA PVC jacket (OD 0.212")Connector A: BNC male...alienth.cn
..Low-Loss 7M [Meter] long pair of cables
$109.00
..Q-- Connect stubby 2.4 & 5.8GHz
[USE When DUO II EXTENDER Not In Use]
$19.90
ALIENTECH 2.4G&5.8G Dual Band antenna of omnidirectional with QMA quick release for Modified DJI drones controller
The antenna is 2.4G&5.8G dual-frequency band omnidirectional, 4dBi gain, with QMA quick release.alienth.cn
$469.00 + 39.90 + $15.00 + $109.00 +$19.90 = $652.80
$652.80 + Shipping + Taxes
GOOD LUCK!!
Hey richinAZ.I haven't flown my SkyDeuce...Yet.
$469.00
Don't Forget The::
$39.90
$15.00
$109.00
$19.90
GOOD LUCK!!
