Skydio photos needed
Theta
Approved Vendor
Website
theta.limited
I'm developing some opensource software that takes metadata from drone still-images and uses it to find the spot it's looking at on the ground
Examples (DJI images):
(I've marked the center of each image with a red dot for demonstrating the concept. As you can see, the location derived is almost in exactly the same place as the center of the image)
I'm looking for example photos taken by Skydio craft to test with. Ideally, a certain building, feature, or other locate-able spot should be in center of the frame, but any images will do as long as they have their original metadata
-Matthew
Great photo, just what I'm looking for
Here's the command I ran to get the terrain data for Huntington County IN:
Here's what OpenAthena found with your image:
Here is the XMP data of your image:
I discovered a bug with how I handle coordinates and the EXIF make tag
Thanks for the example photo, really helps a lot for development
Reactions: somewhereinusa
Looking to get more test images with Skydio craft
Software is now capable of automatic usage of photos taken by Skydio craft, but I'd like to have more test photos to make sure it works for all models and edge cases
Check it out free @ OpenAthena.com
Ok, so they changed the metadata format for newer firmware version, OpenAthena doesn't work with newer versions I guess
Looking into it now...
I sure hope this technology can and will be applied to search & rescue applications. A recent PiXL drone show video/podcast mentioned the challenges in scanning a scene with a drone to do search & rescue operations. It's apparently & understandably challenging to keep track of the ground that was already scanned real time with the drone camera to efficiently search/scour the terrain. It seems like basically what your doing could be adapted for this lifesaving use case.
I just pushed out an update, OpenAthena is now working with the images from your "Walk in the Park" video. I think this should also be the case with still images taken by the latest firmware, but I'm not sure yet
Thanks @LaunchedPix , yeah search and rescue (SAR) is a great application of this software. Terrain matches are quick to run and surprisingly accurate, I hope this technique will be used more frequently. Hopefully this software will help save lives
Reactions: LaunchedPix
That looks pretty cool & useful!
PackTactics
