So what wire do I need to connect the Skydio 2 controller to my Samsung tab A ?
ThomasH
Thanks I will reasearch. Just though someone might be using this
Try using this "Samsung" link to help answer your questions.
The click down arrows opposite each usb type provide pictures and comments to help identify your usb type.
I do use it but once again they do not all use the same connector.
You need the model number you have to get answer.
Easy to find in settings/About Tablet/Model@Hardware
Example:
SM-T290 is microUSB so I use USB-C to microUSB cable.
Reply from SKYDIO
Hi Thomas,
I don't know of a cable that will work for that tablet and our Controller, as the connection has to be capable of USB 3.1 data transfer speeds. Your current device will only support, microUSB 2.0.
Best regards,
  • Angry
Reply from SKYDIO
Hi Thomas,
Best regards,
That was amateur hour at it's best....
If your A Tab has microUSB port just get cable like this and you'll be fine
Plenty of them listed on Amazon or FleaBay
AirSpur98
