Setting height floor above 8 feet, maybe 30 feet to avoid power line
pawntan
How do I set the height floor limit to 30 feet ? The app stick the height floor to 8 feet if height floor is enabled . I do not see a way to change to 30 feet .
I need to set the drone up high above power lines on the streets
I don’t think you can set a height value. It’s just an on/off toggle.
I’m guessing the design intent was to keep the aircraft above head height as it flys autonomously to reduce the chance of accident.
Nice idea to be able to set it to a desired height though. Perhaps you should suggest it to Skydio as an improvement.
really good idea, +1. submit them a request via email or via chatbot on the website
It seems like setting height floor above power line is common sense feature . Skydio should have thought about this. Ok I'll send request
